The third revision of the classic Xbox Wireless Controller was released in November 2020, bundled with the Xbox Series X and Series S. This controller is backwards compatible with previous Xbox One consoles, and PCs.
The charging part and analog part do not work properly
Hello, my problem is that when I put the xbox charger in, it does not charge. If I put it on a bumpy place or hold the controller up a little, it only charges. The problem with the analog is that it goes in-game by itself. It is difficult to deal with this and the analog can rotate (it should not normally). If this information is not enough, I can explain it in more detail.
Add a comment
1 Answer
Chosen Solution
Hi!
Okay so for the charge port first. Did you tried another cable? I would try this first!
If you've tried this, but it still doesn't work, then you do need to replace the charge port!
For the joystick, this issue is common. You can replace the joystick to fix this.
Be aware that you need to have to solder for both parts and you do need solder experience to do this.
Score 1
Add a comment
Add your answer
SendemiBrütüs will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 99
