Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Touchscreen works badly after installing new front panel
(Iphone 3GS 16 GB)
Hey,
i removed my broken touchscreen few days ago and installed a new one, using the instructions on ifixit.com. At first sight it looked like everything was working but then i found out the bottom part of the touchscreen doesn't react. The upper sector does react, but not even nearly as good as my original one before ( even in broken condition).
I wonder what's the reason...
Guess it may be hard to analyze the problem without seeing the phone but If i'd demaged something just as the ribon cable 2 would the touchscreen work partly just as it does ?
I used a quiet cheap front panel so could this be the only reason for the faulty ?
Would be so great if you'd tell me your expections, because i just don't know if it would make sense to buy a high quality panel and install it.
Thanks!
Score -1
Add a comment
Most Helpful Answer
The only times I have had this issue either:
- The connector wasn't fully engaged and just needed popping off and re-seating
- Small tear in the cable for the connector
- Bad part
there is a slim chance that the connector on the logic board itself was damaged in the original incident but I think I've only seen 1 phone with this issue and I put it down to a DIY fix gone wrong.
Score 2
1 Comment:
Lena, sounds like a bad digitizer. Contact your vendor and see if they are going to replace the one you have.
by
Add a comment
Definitely sounds like a bad digitizer to me. Or just the ribbon connector, worth checking if it's popped on properly.
Score 1
Add a comment
Add your answer
Lena will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 488
