The Yamaha P-125 is a compact digital piano that combines incredible piano performance with a user friendly minimalistic design. Easily portable and extremely accessible, this instrument allows you to experience the joy of playing the piano on your terms.
Piano won't start
Piano is completely of and won't come on
Score 1
1 Comment
Hi @adolphussbeah
Have you checked that there's 12V DC on the output plug of the power adapter used to power the piano or tried using another known working compatible 12V power adapter to see if the piano works?
What have you tried?
by
Add a comment
1 Answer
Most Helpful Answer
@adolphussbeah always start buy checking your AC adapter. Make sure that it has the proper output voltage and that the connectors are both in good working condition. If it is, then I would suggest you precede by testing the voltage on your DM board. Follow the flowchart and test the points to make sure you have the voltages.
To help you to get to those boards. we will need to actually see your piano. Adding images to an existing question
Score 1
Add a comment
Add your answer
Adolphus S. Beah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 260
