The Samsung Galaxy A52s is Samsung's upgraded variation of the Galaxy A52.
How to replace a broken vibration motor?
Some time ago I noticed the vibrations of the phone being kind of strange like the vibration motor was loose inside the phone or something. The vibrations rattled even in my hands. Now, however, the vibration is gone entirely. Even when I test the vibrations in the diagnostics panel, I get nothing.
I live in a region where Samsung certified repair shops are in limited numbers. There's only one in my city and they told me that they are not sure if it can be fixed. Is there something I can do to fix it or do I just have to live with it?
Thanks!
1 Comment
HOW TO FIX THE VIBRATION ON MY SAMSUNG A52s ?
by
Add a comment
1 Answer
Most Helpful Answer
Hi,
There’s an ideal iFixit guide for you to follow here:
Samsung Galaxy A52s Screen replacement
It’s a screen replacement guide which includes steps to remove vibration motor, but you’ll only need to go as far as removing the top mainboard.
The vibration motor isn’t mentioned until after the battery is removed - if you watch the battery being removed he then tells you about the vibration motor at the upper end where the mainboard was removed.
Hope this helps
Score 1
Add a comment
Add your answer
Daedalus308 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 95
All Time: 1,760
