Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Question Closed
white screen ,touch screen stop working
Hi all, does anyone ever experience the same problem as i am facing now.
after i drop my 3GS, screen shows WHITE ONLY, and i try to slide the unlock but no sound of "unlock", seems like my touchscreen stop functioning.
when i press the power button, the screen just show a white blank to me, same goes to home button.
but the speaker and vibrate still working,
when i plug in the charge cable, there is a sound of "charging" but still shows white screen.
i try to use to force switch off step by pressing home button & power button but it just off within 6 or 7 seconds? isn't it too fast because i assume it will off in 10 seconds, after that it switch on automatically without press power button and the display screen didn't even in white screen when the moment it ON (looks like it is OFF)
it will only shows white screen few seconds after it automatically ON if i press the home button or power button.
Add a comment
Open the phone and check connectors 1 and 2. If they are loose, put them in tighter.
4 Comments:
no they are not. already checked 1 & 2... :(
by
There's a chance that the digitizer and the screen are broken, get a screen assembly. It costs 100$ on ifixit.
by
how to check the digitizer and the screen ?
by
Try them with another iphone like Joe suggested below.
by
Add a comment
You can get a dig/screen assembly on eBay for about $40.
If you have a friend with a 3gs, swap your friends into yours and see if it works.
Add a comment
Same exact problem...any help?
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 807
