Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
Face buttons sometimes don't work (ABXY)
I'm posting this here as a possible solution to buttons not working or being temperamental
Issue: Face buttons sometimes fail to register (ABXY)
I first tried cleaning the membrane and pads on the board with isopropyl alcohol with no affect.
Then tried a replacement membrane which didn't work either.
I then examined the board under a microscope and found some of the legs on the socket connecting the bottom and top board have become detached from the board:
The legs actually have about a 1mm gap between them and the pads and only have a tiny amount of solder holding them on at the very tips making them quite weak joins. I counted a least 3 dodgy looking legs. I ended up adding more solder to all the legs on the socket (top and bottom board) to make a stronger connection (remember to use lots of flux to help stop bridging!).
It now works great again
Add a comment
1 Answer
Chosen Solution
Answer in first post
Add a comment
Add your answer
sammy3 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 134
