Guides and repair information for washing machines produced by Bosch, a German engineering and technology company.
Software reset for Bosch Series8 9kg washing machine
How to reset Bosch Series8 9 Kg/1400 rpm Washing machine?
Add a comment
Hi,
Found this information at
https://diyfixit.co.uk/how-to-reset-bosc...
Steps are pretty simple and only takes about 15 min (most of that is waiting).
If you’re looking to reset a Bosch Serie 8 washing machine, follow the steps below. Keep in mind that specific instructions may vary depending on the exact model, so it’s always a good idea to refer to your user manual for any unique guidelines or clarifications.
Power Off:
  • Turn off the washing machine using the power button or switch.
    Unplug the Machine:
  • For safety and a proper reset, unplug the washing machine from the power source.
    Wait:
  • Let the washing machine sit unplugged for around 5 to 10 minutes. This will allow any residual power to dissipate and will help in resetting any electronic glitches.
    Plug it Back In:
  • After waiting, plug the washing machine back into the power source.
    Power On:
  • Turn on the washing machine using the power button or switch.
    Run a Rinse/Spin cycle (optional):
  • If you’re resetting due to a glitch or error, it may be a good idea to run a rinse/spin cycle without any clothes in the machine to ensure everything is functioning correctly.
    Check for Error Codes:
  • After the reset, check to see if any error codes are displayed. If they persist, you may need to address a specific issue with the machine.
If a simple reset doesn’t resolve the issue you’re facing, and the problem persists, consult your user manual for troubleshooting steps or contact Bosch customer service for further assistance.
Hope this helps
Add a comment
My washing machine Bosch exxcel 8 vario perfect is not working
After pressing start button speed perfect flashes key symbols flashes
Stuck on 1.31 timer stick on 60 % and 1400 spin
Tried turning off at socket and unplugged for 1/2 hr back to the same info on the screen
What can I do next
Add a comment
I purchased a property with a relatively new stackable Series 300 W/D. Apparently the previous owner programed predetermined settings. I would like to know how to erase those settings and change the settings to manual. This would allow us to allow for the size of each load in the washer OR the dryer.
Thank you in advance,
kg
Add a comment
Add your answer
Tariq Al Deek will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 51
Past 30 Days: 246
All Time: 3,347
