The Dell OptiPlex 745 small form factor is a compact desktop computer that has been a work office favorite, and still sits at desks to this day.
Why is my CD drive not opening?
When I press the CD drive button it does not open what to do?
1 Comment
@rufiniqbal what have you checked? Do you have power to the optical drive (CD drive)?
by
Add a comment
Most Helpful Answer
Hi @rufiniqbal
Check if the cd drive tray opens if you click on the eject setting for the drive in Win Explorer.
Go to Win Explorer (press the Win key + e key - both together) > This PC > right click on the CD drive icon > eject.
It it opens OK, then the eject button on the drive may be faulty.
If it doesn't open, then there may be a problem with the tray motor or the drive electronics and further testing would be required to find the problem.
Score 1
Add a comment
You can try to force restart the computer
if that does not work, if there is a small manual opening hole in the drive door you can put a sim ejector tool into that to manually open it.
Or just stick a jimmy tool and pry until you can pull it out with your fingers
Score 1
Add a comment
Add your answer
Rufin Iqbal will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 122
