Announced on October 13 and released October 23, Apple's flagship smartphone for 2020 features a 6.1" OLED display, a triple-lens rear camera system with LiDAR, and 5G. Successor to the iPhone 11 Pro.
What part contains the mic?
Need to replace my microphone but I don’t see it listed anywhere. What part includes the mic?
Add a comment
1 Answer
Most Helpful Answer
You are going to have to be more specific; there are three microphones on the iPhone 12 Pro model, depending on what you're doing.
The one primarily used on phone calls is located at the bottom of the phone and is mounted on the charging port assembly.
A second microphone is used when you're on speakerphone or using the selfie camera and is located on the earpiece speaker assembly mounted on the display.
The third one is on the rear side of the phone in the middle of the cameras, and is mounted on the flash assembly.
In each of these images the microphone can be seen as a small gold-colored rectangle.
You should be aware that replacing the earpiece speaker assembly will cause you to lose Face ID. There should be no issue replacing any of the other microphones.
Replace a lightning connector assembly compatible with an iPhone 12 or 12 Pro. Includes the flex cable, logic board connector, lightning connector socket, and one microphone. Part #821-02627. Image
Product
iPhone 12/12 Pro Lightning Connector Assembly
$26.99
Fix a malfunctioning flash with this replacement assembly. Image
Product
iPhone 12 Pro Flash Cable
$29.99
Replace an earpiece speaker or sensor assembly compatible with the iPhone 12 and 12 Pro models A2172, A2402, A2403, A2404, A2341, A2406, A2407, A2408. Image
Product
iPhone 12/12 Pro Earpiece Speaker and Sensor Assembly
$32.99
Score 1
Add a comment
Add your answer
chevroleddie will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 39
Past 30 Days: 139
All Time: 1,282
