Announced on October 13 and released October 23, Apple's flagship smartphone for 2020 features a 6.1" OLED display, a triple-lens rear camera system with LiDAR, and 5G. Successor to the iPhone 11 Pro.
How can I replace the Loudspeaker mesh?
I want to replace the loudspeaker mesh of my iPhone 12 Pro, what should I do?
It was necessary to sell separately in repair companies, but only sold separately.
So I want to do it directly. How should I do it?
Add a comment
1 Answer
Most Helpful Answer
I am unsure of which mesh you are referring too but here goes both
  1. The one I think your referring to, the mesh on the bottom of the phone. To replace this you would have to replace the whole casing of the phone which you probably dont want to do. If the only problem is that they are dirty, take an old toothbrush and compressed air can and scrub with toothbrush and remove excess with air. Repeat until clean
  2. The second mesh is on the top of your screen and to replace it you would need to (I believe) replace the screen. This is also pretty expensive so what I would do is just do the same thing as what was listed in number 1 just take greater care not to damage the screen or selfie camera(and lose face ID)
Score 1
2 Comments:
I am in situation 1, is it impossible to replace only that part without changing the case?
I thought it could be replaced by selling parts separately, but is it a structure that cannot be disassembled?
by
@macnabi yes, the wire mesh of the bottom speakers are attached to the main frame of the phone, and to answer your question no the mesh cannot be swapped out
by
Add a comment
Add your answer
mac nabi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 13
All Time: 188
