Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3239 Questions View all
How to repair an iPhone 4 following a contact with water?
Hi,
Following a contact with water, my iPhone 4 doesn't work anymore.
For information, I tried to recharge it just after the incident.
What can I do to solve the problem?
Thank you in advance.
Alex VIROLAN
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Alex VIROLAN, not knowing how bad the water damage to the phone was, I would start with cleaning the phone first. Use this guide as a general guide, It was written for a 3G but the principals still apply. Use these guides to work on your phone. Once you have that accomplished, change the battery and reevaluate. Should you still have trouble with the charging, replace the dock connector. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Alex Virolan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 324
