Which graphic card support?
In this dekstop which graphic card is support???
Score 1
Add a comment
1 Answer
Most Helpful Answer
@soumenmaji there are actually quite a few but these are the common ones:
GPU upgrade options for Lenovo ThinkCentre M82 Tower with the stock 450W power supply
GPU Power consumption Memory Req.
NVIDIA GTX 1660 Super 130 W 6 GB DDR6 *SATA to PCIe adapter
NVIDIA GTX 1660 Ti 125 W 6 GB DDR6 *SATA to PCIe adapter
NVIDIA GTX 1070 145 W 8 GB DDR5 *Dual SATA to PCIe adapter
NVIDIA RTX 3050 130 W 8 GB DDR6 *Dual SATA to PCIe adapter
  • Typically, the stock power supply in a business PC does not have the necessary 6 or 8 pin connectors to power the GPU. In such cases, you may need to use a low-power GPU or a SATA to PCIe power adapter. Alternatively, you can change the entire PSU. from here
To work on your Lenovo use this ThinkCenter Hardware Maintenance Manual
Score 1
Add a comment
Add your answer
SOUMEN MAJI will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 407
