Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1959 Questions View all
iPhone 3GS will not take charge,shows usb plug interesting?
I have a real problem. Phone started to shut down randomly and would not take a charge and shows plug symbol(usb). I have changed charger, battery(correct for 3gs) and charge port. I have updated etc via Itunes. still no joy phone works fine on new battery until power drops out. Do you think this is terminal and a motherboard failure?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Catherine, given the fact that you do have A. a new battery B.a new charger C. a new dock connector, there are only a few things you could do. Change /use a known working USB cable. If that does not resolve it, you can check the charging and USB fuse on the logic board and see if you have continuity. If those work out and are okay, you have deeper problems, like the power management IC.
Score 1
Comments:
Thanks oldturkey you seem very knowledgable I will have a look tomorrow and let you know
by
Thank you , but the real expert is pollytintop :-) good luck
by
Add a comment
Add your answer
Catherine will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 731
