The seventh-generation Golf had its début in late 2012 at the Paris Motor Show.
Why can't I change the language settings
How do I change language settings on my radio to english
Score 1
Add a comment
1 Answer
Chosen Solution
To change the language settings on the radio of a 2012-2019 Volkswagen Golf to English, follow these general steps:
1. Access Settings Menu: Turn on your car's ignition without starting the engine. This will power up the radio. Navigate to the main menu or settings menu on your radio display screen. This is usually done using the buttons or touchscreen interface on the radio.
2. Language Settings: Once you're in the settings menu, look for an option related to language or language settings. Depending on the model of your Golf and the software version of the radio system, this option might be labeled differently. It could be something like "Language," "Sprache" (German for language), or represented by a language icon.
3. Select English: Scroll through the available language options until you find "English" or "Englisch." Select this option to change the language setting to English.
4. Confirm and Exit: After selecting English, confirm your choice if prompted. The radio display should now switch to English. Exit the settings menu and return to the main radio interface to see the changes.
If you're having trouble finding the language settings or if the specific steps vary for your Golf model, refer to the owner's manual of your car for detailed instructions. It should provide specific guidance on how to change the language settings on the radio.
Score 1
1 Comment:
It's in japanese
by
Add a comment
Add your answer
Napo will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 81
All Time: 2,267
