The 4X4 desktop case used on many Packard Bell computers. It can be easily identified by the 2 5.25" drive bays on the front.
operating system not found?
operating system not found ?? i have checked all of the drives sepearttly, they seem to work.. but the 1994 packard bell says operating system not found. i have tired to boot from a floppy, and it tells me to remove disk and continue.. then i get diddo operating system not found, i am stumped..
2 Comments:
i have tried to reset things in the bios, and it perfers to load defaults, i had upgraded the dead battery, so it keeps current time,,
by
Hi @gerryfranc26930
Intrigued by your question as I've never heard of a Dido OS if this is what you mean.
If it is then looking at this it seems that it is a program designed to work on Windows (or Linux) and not a separate bootable OS but maybe I misinterpreted it.
by
Add a comment
May be the os were currepted, try to install os again. It may fix the issue
Add a comment
Hey! Ah, the nostalgia of a 1994 Packard Bell! I remember having a similar issue with an old PC I was trying to revive. It can be super frustrating when it keeps saying "operating system not found."
One thing that worked for me was checking the BIOS settings to make sure it was set to boot from the correct drive. Sometimes, these old systems can reset their boot order for no apparent reason. Also, double-check if the hard drive connections are secure.
When I was troubleshooting my old machine, I stumbled upon some great advice on operatingsystems. They had some tips for dealing with vintage hardware issues that were surprisingly helpful.
Add a comment
Add your answer
Gerry Franco Roberts will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 43
All Time: 374
