The MSI GL65 9SD is a budget gaming laptop made by MSI computers released in 2019. Repair guides and further information can be found here.
Why is my screen off
Please a metal screw fell inside the laptop, stacked between the metal that covers the cpu and the motherboard. I didn’t know so I connected my laptop charger to the laptop and the charger light went off. I tried this several times until I opened the laptop and removed the screw. Now the laptop turns on but the screen is off. When I connect to a monitor, it doesn’t show too. Please what could be the fault
Add a comment
1 Answer
You seem to have loosened the heat sink (that metal part) if the screw got trapped onto the motherboard than it is possible that you damaged the motherboard (really bad). You could also try to check the connection to the GPU and the actual card itself for damage and the fragile ribbon cables around it
Add a comment
Add your answer
Michael Ashorm will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 22
All Time: 216
