Fix Samsung TV broken screen
I’d like to know where I could get a new screen for Samsung model QA65Q65BAKXXT replacement screen
Add a comment
1 Answer
@lieson you will find that display panels most often cost more than a new TV. Shipping is also not just risky but very expensive.
To find a replacement, remove the back cover from your TV. There will be a label glued to the sheet metal backing cover of the display screen. Use the manufacturer number for the panel to do an online search. Sometimes you can find used ones on either ebay or similar sites. If not, then you may need to consider purchasing a TV with the same display panel but that had other issues. Then harvest the display assembly for your original TV from that
Add a comment
Add your answer
lisankhaleel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 204
