Backlight stopped working, iBook G4
My friend's ibook G4 started having an intermittent backlight. It would only work at certain angles. Thought it was the cable (through the hinge) but have continuity. SO I saw the TH micro fuse answer, but that checks out OK also. So now I am thinking it is either: 1) inverter board or 2) display.
I was going to start with replacing the cable, but ordered a 184-000-1 but it is not the one for this display.Is 1" but connector is different at display end ;(
Because it was working at some display angles, I still suspect the cable or inverter.
Thanks,
Carl
Score -1
Add a comment
Chosen Solution
If, when it goes dark you can still see the desktop, replace the inverter cables. If it goes totally black, replace the Display Data Cable.
Score 5
Add a comment
Well, if the backlight works at some angles, the cable is a likely culprit.
Usually the components involved in a faulty backlight are:
1. A worn out cable, that intermittently works, so, while "resting" may have continuity, when pinched or moved disconnects itself because of broken/pinched parts
2. A worn out inverter
3. A broken backlight.
So to rule out damages, you should attempt a cable change. If doesn't work, an inverter change, and only if it doesn't work, an LCD replacements.
Also, some expert users may replace the CCFL lamp inside the LCD, but that's a tricky, hard-to-do operation.
Your diagnosis is correct, try how it works with a better cable, if it doesn't work go for the inverter.
Score 3
Add a comment
Thanks, guys. My backlight would go out whenever I moved the display, but I could faintly see my desktop on the screen. I took it apart and inspected the inverter cable, hoping to see obvious damage, but didn't see any. After I started to peel back the shielding on the cable, the red wire must have been worn down to a single thread because it came right out, broken about an inch down into the shielding. I replaced the cable, and all is good now!
Score 2
1 Comment:
I'm glad one of these old questions & answers could help you.
by
Add a comment
Add your answer
caschultz will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 12
All Time: 834
