Lenovo Yoga Smart Tab tablet was launched on 5th September 2019. The tablet comes with a 10.10-inch touchscreen display offering a resolution of 1920x1200 pixels.
Network problem {emergency call only}
Network problem sometime it goes to zero, and after 2-3 hr it came back, tried everything Simcard, roaming, restart many times etc.
Add a comment
1 Answer
Well I will suggest you to do the following:
  1. Check if Your SIM Is Active and Turned On.
  2. Switch On and Off Airplane Mode.
  3. Change Your Network Type if you are using 2 sim's in your tab
  4. Manually Select Your Network Provider.
  5. Restart your tab.
  6. Check if Your SIM Is Inserted Correctly.
  7. Clear the SIM Toolkit App Cache and Data.
Add a comment
Add your answer
Utshah gupta will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 254
