Why does my Infinix Hot10 touch screen like to touch itself?
@ruangelkab51574 what you are describing is called "Ghost Touch". That is an issue between the touch screen and the display assembly. The only way to fix that is by replacing the display assembly.
Since iFixit does not yet have a guide for that, use something like this video to work on it. Replacement display assembly are readily available at many online stores.
One more thing, before you tear things apart. Check if you have a screen protector. If so, remove that and see if the "Ghost Touch" now stops. If so it is your screen protector that is causing this.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 17
