Logitech Rumblepad™ 2 - Not detected anymore by any OS
M/N: G-UF13
P/N: 863247-0000
Circuit board: E-P03-M566PA7.5
I need help identifying possible causes and solutions.
- It stopped being usable on Windows 8.1: when plugged, Windows would attempt to install its drivers (although it's plug and play) and return the balloon message of not installed properly and/or unrecognized device. Wouldn't even show up in printers and other hardware like it used to. It would flash the light for about 1 second (apparently when I pressed the vibration button to make it react).
- Plugging it into another USB port would not change.
- Now it does not even make Windows try to install anything and the light does not flash.
- It seems to conflict with USB mouse and USB keyboard, making it stop working and having to restart Windows to make those peripherals function again.
- Tested also in another computer where it used to work, in Windows 7, and there is no reaction.
- Tested with Linux Mint to make sure the problem is not the operating system and it does not work either and it is not even detected (tried the
lsusbcommand). - The cable seems fine (visually) and in the circuit board cannot notice (visually) any damage, only:
- some dirt;
- some excessive glue;
- some varnish-looking coating (transparent glue?) around some solder;
- some rust (or is it just dirt) on the vibration and analog parts.
- I tried the official website (https://support.logi.com/hc/en-us/articl...) and there is no documentation about this old product. I asked for any offline documents they could have through chat costumer support but was left with void after the human member told me I would be transferred to my region's chat.
- I have searched for anything I could find and there is only these pages that can be used for comparing my photos with a working and clean device (the links are from the translated pages):
Score
it might have suffered internal hardware failure.
just take the controller to a professional technician for a repair.
by Mouhibe Slama
Thanks, but that will constitute the classical problem with these kind of objects: the repair cost would surpass the value of a new one.
by Properly Malfunctioning
Most likely motherboard and/or cable. It will be hard to tell what part actually died... Replacing the motherboard is a nice start, but as you already said it, it's better to get a new one... Sorry.
by koppie007
