Repair manuals and support for 4-wheeled passenger and cargo vehicles.
11874 Questions View all
How do I replace the windshield wiper linkage in my 1999 Isuzu Rodeo?
my drivers side windshield wiper quit working I took it in to have it fixed they temporarly fixed it now it is broke again. They want to charge me 300 to fix it. all i need to do is replace the linkage how do i do it
Score 1
Add a comment
1 Answer
Chosen Solution
Here you go:
Removal
1. Disconnect the battery ground cable.
2. Remove the windshield wiper arm/blade.
3. Remove the vent cowl cover.
4. Remove the windshield wiper motor.
5. Remove the pivot assembly mounting nuts, fixing screws.
6.Take out the windshield wiper linkage assembly from the opening of the cowl.
Installation
To install, follow the removal steps in the reverse order
Windshield Wiper Motor Removal
2. Disconnect the connector(2).
3. Remove 4 mounting bolts.
4. Remove the nut of the wiper motor shaft, and
disconnect the linkage.
5. Remove the windshield wiper motor(1).
CAUTION: To facilitate the removal of the nuts, be
sure to put out the tip portion of the linkage
sufficiently through the mounting hole of the motor
by sliding the wiper blade slowly.
Hope this helps, good luck.
Score 4
Add a comment
Add your answer
connie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 20
All Time: 6,332
