Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
iMac don't start...second LED lights up intermittently every 3 seconds
Hello
Already replaced power supply with the power supply of my other 2012 iMac 27"...and do the same...
Any help to find what is the fault?
Best regards
Add a comment
1 Answer
What transpired before you replaced the power supply? Did you alter anything like add memory, replace the CPU…
9 Comments:
Hello
One year ago (more or less), when reassembly CPU on socket (after replace Thermal Past/Thermal Pads), bent 2 pins on socket (but correct this issue), also "split" Fusion Drive (replaced the Apple "Blade" with a OWC 480Gb and SSD SATA Crucial MX500 2TB), upgraded RAM from 8 GB to 32 GB, replaced PRAM battery(BR2032)... and works great for a year...
Some days ago iMac won't start...I changed the power supply because it didn't start...but don't solved the issue...
Could this be related to the issue of socket bent pins ? (a year ago)
by
@boxerboss - Sadly yes 😡 the bent pins are weaker and over time fail. You could try reseating the SO-DIMMs. Do you have an external bootable drive to double check if the current boot drive is messed up. But I’m leaning the socket is the issue.
by
Hello
I already removed RAM and put it back in...issue persists
Do you mean to try with a USB bootable Big Sur?(the macOs installed)...and try to start in Recovery Mode?...or Safe Mode ?
by
@boxerboss - I just find having a bootable external drive is quicker to just boot up from. You can also try booting up under anyone of the Startup options, do any respond?
by
Can I create a "bootable external drive" for my iMac in other Mac?
by
Show 4 more comments
Add a comment
Add your answer
JOAQUIM LOPES RAMALHOSA will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 126
