Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
phone will not turn on
Had my phone in my pocket and pulled it out and it was off. tried turning it back on and it did nothing.
Score -1
Add a comment
Chosen Solution
Joshua, try this:
"Hold the sleep/wake button and the home button at the same time. Keep holding both until you see the screen go black. You may need to hold them even after the red slider appears. If it does, just keep holding the buttons until the white Apple logo appears.
Hope this helps, good luck.
Score 1
Add a comment
Most Helpful Answer
Hi Joshua,
It might help to connect your iPhone to your power supply and see what happens.
Sometimes, batteries run low very quickly. I suggest to check that out first before you do anything else.
Steffen
Score 1
Add a comment
Add your answer
Joshua will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 266
