The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering.
284 Questions View all
The bottom half of the touch screen don't work
What can I do to fix this problem
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Chosen Solution
Tammy Adams, you can try with a reset and a restore first. If that does not work, disassemble your phone, check the cable for proper connection. If it is properly connected, no corrosion or debris on the logic board, replace the digitizer. Check this video to see if you are up to that task. Also remember that the Original 2G iPhone Glass repair will cost you more than the 3G iPhone Glass. The 2G uses an assembly of the glass, digitizer, and LCD screen. the assembly is available at places like this. Hope this helps, good luck.
Score 2
Add a comment
It must be the digitizer went bad, sadly its kind of expensive around $70 for an OEM lcd and digitizer assembly as they come as one unit.
Theres a guide how to replace the display assembly on a original iPhone and lots of videos on youtube.
Add a comment
I agree with Luis. However I would not try to replace it unless you know what your doing.
You can get a online repair shop to do it for around 70 bucks.
Try this site ifixit.com or ipodrefresh.com
Add a comment
Add your answer
Tammy Adams will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,139
