Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
Battery replaced and I’m scared of the old one
Old battery scares me more than being in Iraq. There’s a sickly sweet smell coming from it. Tried to seal it away in the replacement box and a bag. I really want to call the fire department for real.
What else can I do? How long do these things de-gas for? I’ve never seen a battery do this with out igniting.
Yes I tried the pull tabs they failed because of the battery damaging itself way before I opened the phone. (Apparently years ago.)
Yes I used 99% IPA to breakdown the glue strips.
No the battery is not becoming a spicy pillow.
No the battery is not warm to touch with or with out gloves.
Score 2
Add a comment
Most Helpful Answer
I remember I accidently punctured a battery once.
What I did was to simply place the battery in a bowl of salty water and then leave it for a couple hours (or until the water stops bubbling). I would also recommend doing this outside as it does release hydrogen and chlorine which can prove to be a hazard if the area is not well ventilated. This should discharge the battery and make it safer to handle.
Score 1
6 Comments:
I didn’t have the chance to puncture it lol. I used the guitar pick to get it out.
by
This method should still work considering all it does is discharge the battery via electrolysis, which is some interesting chemistry stuff.
by
@mapleinit appreciate it 👍
by
@youweesh No problem!
by
@mapleinit Water? Lithium and water do not like each other at all. Might just create a bit of an explosive gas (Lithium Hydroxide and Hydrogen)
by
Show 1 more comment
Add a comment
@youweesh if you are really concerned about it do what I do. Stick it in a metal can filled with sand. Let it de-gas for a day or two. After that dispose of it according to your local regulations.
Score 1
Add a comment
Add your answer
You Weesh will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 166
