Model A1989, EMC 3358. A refresh of the existing design, with updated processor options and a change to the keyboard materials. Available in Silver and Space Gray. Released in May 2019.
Would I be able to swap a 2018 motherboard, the same size, to my 2019?
I want the Core i7 motherboard in my Core i5 MacBook, as I need some more power, would I be able to swap this? And if so, is there any links to one I can buy? Thanks!
Add a comment
1 Answer
Sure you can swap out your logic board for a better one from within the same series. For referece these are your choices: MacBookPro15,2. You can’t install the other boards into your system.
But be careful! You need to swap out the power button assembly with the logic board that’s mated to it. Here’s a good source 13” MacBook Pro 13 Logic Boards if you have a two USB-C port system you ‘ll need to focus in on these boards.
Sadly, you might not find a logic board that offers the amount of RAM and storage you are looking for, you may need to look for a used system to just use or if the case is in rough shape swap out it’s logic board with yours.
Here’s the guide MacBook Pro 13" Touch Bar 2019 Logic board Replacement
Add a comment
Add your answer
Liz On 420 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 284
