Repair your Dyson V6 Cord-free vacuum with a part replacement guide.
Unit shuts off after running for 15-20 seconds.
Unit runs for 15-30 seconds then shuts off and will not run again for some time. Tried filter change. Overheat issue?
1 Comment:
Battery replacement resolved the issue.
by
Add a comment
1 Answer
Power issues can be hard to pin down. Although they are usually the result of the battery or connections degrading over time, it could be much simpler, and be caused by overheating.
You could start by removing the battery and wiping the connections over. It’s possible there’s a power consumption issue, with there just not being enough residual charge to run the machine. A new battery should fix this.
Dyson V6 Battery
My other thought is that it’s overheating. If too much power is pushed through the motor, which MAX power does, it could stop after a few seconds if it becomes hot. Rule this out by giving the machine an overhaul. Wiping down the individual parts, cleaning the filter, etc.
Replace the 3000 mAh battery compatible with these Dyson cordless vacuum cleaner models: V6, DC58, DC59, DC61, DC62, DC72, and DC74. Image
Product
Dyson V6 Battery
$68.99
Add a comment
Add your answer
Kevin Pope will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 350
