The 5th Generation iPad Air was announced on March 8, 2022. It features the M1 chip and 5G connectivity.
Are these two dark spots normal when viewing from one side?
When I view my top edge from the bottom side, I see these 2 small dark spots (1cm each). Not seeing them with viewing the display from above or normal usage without paying too much attention and dark images are fine.
Is this normal? Or it's a hardware issue?
Add a comment
1 Answer
Are you seeing them within a clean white space? It’s likely the graphic you have is creating the distortion.
2 Comments:
Yes, I still see them if I look from bottom.
by
@alireza83547 - There’s little you can do to alter this slight distortion in the display. I personally would live with it. If it really bothers you then you have to replace the display panel which I think is going a bit far.
by
Add a comment
Add your answer
Alireza will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 17
All Time: 140
