Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
No power, no iTunes water damage
Ok I dropped my iPhone in water. Opened it let it dry then it only turned on when on charger. Won't be recognized by iTunes and one day I plugged it in and nothing showed on the screen. Took it apart and battery has power when plugged in logic board has power help
Add a comment
1 Answer
Chosen Solution
Kadin, the number one thing that you should do, follow this guide. It was written for a 3G but does fully apply to your phone as well. Make sure that you do not leave any part uncleaned, otherwise you will risk later corrosion issues. Once you got this accomplished, replace the battery (make sure it is a battery for the 3GS) and reevaluate what, if any, damage you have. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Kadin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 405
