Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
Keyboard doesn't work after replacing it.
I have an A1990 Model Macbook that I bought second hand and the keyboard stopped working after replacing my battery. So I investigated the issue and found corrosion where the keyboard ribbon and keyboard connect.
I replaced both the keyboard and the keyboard ribbon cable.
The keyboard is still not working, no backlight, and non-responsive. I don't understand why it is no longer working since everything for the keyboard is new.
Add a comment
1 Answer
Does a USB keyboard work (via a USB-A to USB-C adapter)?
4 Comments:
Yeah I am able to use a USB keyboard to login.
by
@razitomeya - So tat helps in limiting where in the logic board you’ll need to investigate is damaged. Are you up to the challenge? You’ll need to grab the schematics and board views for your system, have a good magnifier, narrow tipped soldering and a steady hand!
by
Where can I get schematics? I have done low skill soldering like fixing my xbox controller, but nothing like this.
I would love to narrow it down.
by
@razitomeya - Google the boards number in your case 820-01041you should be able to find them.
by
Add a comment
Add your answer
Razitomeya will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 39
Past 30 Days: 46
All Time: 196
