Question Closed
Flashing Apple Icon after Installing New LCD Screen
I just installed a new LCD screen on my ipod touch 2g. Once I plugged it in my computer, I get the flashing apple icon. When I unplug it, it seems like the ipod has died. I have read many places that restoring it should fix the issue, but my sleep button hasn't functioned properly for some time, sometimes I can get it to work and sometimes I cant. Also ever since I installed the new LCD screen, my computer or itunes doesn't recognize the ipod when I plug it in. I am getting frustrated.
Add a comment
Try taking it apart again, and with the new display connected, disconnect and reconnect the battery.
2 Comments:
Thanks for that info. I will give it a shot and see what happens.
by
I assume you need melt the solder or does it unplug where the ribbon meets the battery?
by
Add a comment
You get the flashing apple icon when the battery is really low....Charge the battery and take a look after 1-2 hours.
You should fix your sleep button, unscrew it, there is a little metal pad under the sleep button, just replace it in the center with glue and it's done.
It hard fix an ipod without sleep and home button.
1 Comment:
charging the battery for two didn't do anything. I just received a new digitizer with the new home button and replaced my sleep and volume buttons also, but the flashing began when i put in the new LCD and then the other part where installed a couple days later. i am stumped at this point.
by
Add a comment
For disconnecting the battery, you have to desolder the connection on the logic board. Take care, don<t remove the 3 solder pads. Use hot solder iron, lot of flux and solder wick.
http://www.youtube.com/watch?v=LrFaXblPn...
If you bought a broken ipod, take a look if you have a missing pad. That can cause the problem.
Take a look on youtube, how desolder an ipod battery.
1 Comment:
Thanks I will give that check out the video. The ipod is mine. Not realizing it fell on the floor, I accidentally stepped on it while wearing boots and broke the digitizer and messed up the lcd screen.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,117
