Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
Open button stuck even after cleaning
So for some reason one of the Ps1s that I have has a stuck open button. I took it apart, cleaned the button and socket, put it back together and the button still gets stuck. Maybe the spring is bad?
1 Comment:
or button too loose, as in diameter not quite large enough.. happened to me
by
Add a comment
1 Answer
My solution to this problem was using a little bit of dry lube to let the assembly slip better. Another fix was sanding down the insert part where it makes the \___ shape at the end down to better work with the spring.
Add a comment
Add your answer
ryansrepairshop will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 236
