Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Why does my phone not sync or charge fron usb?
Hi all, i recently had to change the charging dock on my old iphone 3g. Since then i have found that although it charges fine from the wall socket it won't charge from usb and itunes doesn't recognise it.
I plugged my iphone 4 into the same usb and it gets found straightaway?
I have tried a soft reset and tried wiping it all to factory settings from the phones menu, but this has had no effect and now it is stuck on the screen that tells you to plug it into itunes. Any ideas?
Score -1
Add a comment
1 Answer
Chosen Solution
try putting the old dock back..if it's recognised in itunes then you have a bad part.
Score 3
2 Comments:
Hi guys...all sorted it was a faulty dock connector used another and all is well :)
by
Great job stuart. Now all you have to do is accept the answer that helped you out the most. Again, great job, congratulations in getting it fixed.
by
Add a comment
Add your answer
stuart will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 394
