Changed rear master cylinder now even after bleeding I stillDon’t have
Replaced rear brake cylinder now even after bleeding I have no pressure 2010 Silverado rear wheel drive
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 25
2 Comments
Found out that the new cylinder blew out Not understanding why this happened.
by richard fritts
If by new cylinder you mean a wheel cylinder inside the hub of a set of drum brakes then most likely you did not adjust the brakes properly after you repaired/replaced the wheel cylinder. The brake shows were allowed to spread far enough so as to let the new cylinder come apart.
by Thomas Stigall
