The iO, released in 2020 is an electric toothbrush by Oral-B. It is able to connect to your smartphone via Bluetooth and gives you realtime 3D teeth tracking. Identified by type number 3758. Models include: iO Series 7, iO Series 8, iO Series 9, and iO Series 10.
Why it doesn't charge properly?
It seems to be charged. It syncs, and it shows on the app to be fully charged. Then it stops working and back to 0
Score 2
Add a comment
Chosen Solution
@mercegalle60134 it's entirely possible that this is a bad battery. It may charge but does not hold a charge. I would start with a replacement. Here is a guide for that Oral-B iO Battery Replacement
3 Comments:
It is not a battery problem if he replaced the battery 4 times and still has the same issue. I returned the unit for a replacement. Several months later the exact same issue happened. The batteries are not the issue and should last at least 18-24 months before they start noticeably losing capacity.
I replaced my battery this time. It worked great for a few months and again with the same issue. Full charge and the next brush it stops dead within a minute indicating 0% on the battery.
I removed the battery and re-inserted the same battery. Voila, 98% charged.
There is clearly a design defect with this line. The same thing has happened with my wife's unit; the exact same pattern.
by
@johnczukkermann I do not see where it says that the OP "he replaced the battery 4 times". What you are referring to is an answers that was posted 6 months after this answer. Sure it could be a design flaw, but it can also be an issue with the firmware as well as the charge controller.
by
I had to return the IQ toothbrush 3 times and purchased different levels of the IQ but all will not charge after 2 weeks. So purchased a different brand all together. That they may have a recall.
by
Add a comment
I had this problem. At around 50% charge the brush suddenly dropped to 0%. I had 4 battery replacements over 15 months. I was very disappointed and they eventually gave me a new piece about 3 months. And now this new one has started doing the same thing! It is such a good toothbrush when it works. There must be a design flaw.
1 Comment:
I experience exaclty the same issue... I sent my previous one back under warranty, but it took that subcontractor more than 5 months to send me a replacement...
However the problem is there again...
by
Add a comment
Add your answer
Merce Gallego Galindo will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 66
Past 30 Days: 364
All Time: 13,959
