Repair, disassembly, and troubleshooting information for the Steam Deck with LCD display, a handheld gaming console made by Valve, released on February 25, 2022. Identified by model number 1010.
How to clean the inside components of my steam deck safely?
HI!
I was wondering how I can clean the inside of my steam deck, I never done this before and since I usually use my deck in a very dusty outdoor business, the inside of my steam deck is very dirty.
Thank you in advance for the help!
Add a comment
Most Helpful Answer
Hi @milanorwolf
Here's the ifixit Steam Deck repair guide that will help.
It details how to open the console and remove all the parts.
The first thing that you should do when you start is to make sure that you have a clean work bench and are organized having the correct tools to do the work and enough containers etc to place in any components that you remove, especially any screws etc. so as not to lose them
After opening the console, first disconnect the battery as soon as it can be accessed so as to nullify any electrical problems from occurring when working inside the console. Mechanical damage .e. tools slipping etc is another matter so be careful and concentrate on what you're doing.
Wearing a wrist strap connected to an earth point will also minimize any potential for ESD damage to the sensitive electronic components on the board if you happen to accidentally touch them.
To clean off the dust etc, use a soft brush and gently brush it loose and then use a vacuum cleaner (lowest setting) to remove it from the boards etc.
When finished reconnect the battery just before closing the case for the last time.
If you strike problems, stop and think about it first instead of rushing headlong into trying to solve it as you may cause unnecessary damage. This forum is full of questions from users who tore cables, broke plug latches, stripped screws etc most probably due to impatience more than anything else.
Slow and steady and I'm sure that you'll be OK.
Score 1
Add a comment
Hi! Opening your Steam Deck to clean dust is okay if done carefully, but it’s not something to rush into lightly. First, power off fully, remove the microSD card, and work on a clean surface with the right tools. Once open, disconnect the battery immediately to avoid any electrical issues. Use a soft brush to loosen dust and a vacuum or low-pressure compressed air in short bursts to remove it gently, do not force air deep into components. A wrist strap can help prevent static discharge. Avoid liquids and alcohol inside the device, and reassemble carefully, keeping screws organized. Go slowly, many internal issues come from haste, not dust itself.
Add a comment
Add your answer
Milanor will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 82
All Time: 1,237
