Mac hardware - anything that is made by Apple and plugs into an Apple device including external drives, power adapters, cables, converters etc.
Why won't Battery door will not open on Apple Remote Model No A1156?
Would like to replace the battery in my Apple Remote. No matter what I try, the push/release mechanism will not release the battery tray. Any way to get this door open without damaging the device?
Score 1
Add a comment
Most Helpful Answer
need to get a paper clip or sort, and push down into the little hole and it flips open, to replace battery. battery type is a Panasonic CR2032 3V
Good luck
Score 2
2 Comments:
I use the jack of my headphones, pushing it all the way down. It's thin enough, and sturdy, and doesn't scratch the button as a paper clip could do if you've got jittery hands.
by
This worked. You have to push harder than you would think.
by
Add a comment
This seems to work only with the new "silver" remotes. I cannot find any way to open the original White ones. Does anyone have information on disassembling the white A1156 EMC 2086 models?
3 Comments:
Stefano's tip worked for my white A1156 EMC 2086 models
by
Ok Steve, I too, have the identical remote... and had trouble opening it. After reading the above comments, let me just confirm that you need to use a semi pointed object to press in the small round circle located on the bottom of the remote.... I used a standard size nail (as in hammer) and finally the battery tray popped loose. Note that the circle will be hollow when popped out... If somehow, the remote became sticky and the spring mechanism is gummed up, do what you need to do... like place the bottom one inch (1") in hot water being carful not to submerge the button area into the water... this should free up the geewie stuff freezing the spring loaded tray. Good Luck
by
I found that a handheld hair dryer on the "low" setting worked pretty well and didn't risk water intrusion. The hot water method didn't seem to unstick the drawer tray sufficiently. These are now old remotes, but we misplaced a newer one, and the Gen 1 remote seems to work fine with a Gen 3 Apple TV.
by
Add a comment
In case anyone still needs an answer to this question here is the link to Apple Support answering this question. http://support.apple.com/kb/HT1306
Add a comment
Add your answer
Steve Mattson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 4,742
