Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
Can I use the LCD on this iMac for another iMac?
Hi there,
I have a 21.5" iMac Late 2009 A1311 and I was wondering what iMacs are compatible with the lcd screen that this iMac uses, since my friend has a 21.5" iMac 2011 that requires an lcd screen and I don't know if this one would work or not.
Thank You
Add a comment
Chosen Solution
Sorry no. Apple loves to make things different!
Here’s the 2009 part Apple P/N 661-5303, LM215WF3(SL)(A1)
Here’s the 2011 part Apple P/N 661-5934, LM215WF3 (SD)(C2)
Score 1
Add a comment
@drelmoh you can't (Plug and Play;-). The 2009 LM215WF3 (SL)(A1) use an 8 Bit 2 port LVDS interface
and the 2011 LM215WF3 (SD)(C2) use an 8 bit 4Lane Display port interface. Not compatible with each other.
Now, with that said, if you want to get really inventive, there are LVDS to DP adapter boards that might just work for you :-)
Score 1
2 Comments:
That's actually a good idea. Thank you
by
@drelmoh Reduce, Reuse, Repair, Repurpose, and lastly Recycle. Where there is a will there's a way :-)
Repair is War on Entropy!
by
Add a comment
Add your answer
Dr. El Moh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 78
