Repair guides and support for LED, LCD, HD and other Vizio TVs.
932 Questions View all
The remote no longer works after turning on my vizio tv with it. Why?
The TV turns on when I press the power button with my remote but then I can do nothing else. I can't even turn it back off with the remote. How can I fix this?
Add a comment
1 Answer
Most Helpful Answer
Hi @kris10341
What is the model number of the TV?
Try resetting the TV and see if that fixes the problem.
Disconnect the power to the TV and then press and hold the TV's Power on button (not the remote's) for 30 seconds and then release it.
Reconnect the power to the TV and check if the remote now works OK.
Can you operate the TV using the TV control buttons?
If so and if the remote is not working, use a digital camera or the camera app in a mobile phone to check if the remote is OK.
Turn on the camera (or open the app) and point the end of the remote that is usually pointed towards the TV, at the camera lens.
When viewing the remote in the screen of the camera or phone, if you press any button on the remote you should see a light turn on at the end of the remote.
If it is there then the remote is OK and it may be a problem with the TV's IR receiver. This receives the infra red signals from the remote control
Score 1
Add a comment
Add your answer
Kris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 26
