Repair guides and support for your LG TV.
1379 Questions View all
The tv will not power up The standby light come on then turns off
Hello I have a LG 55in TV that will not power on, I’ve tried the rest procedure and it still acting up. I’ve notice that the Red standby light is not on. And when I attempt when I tap the power button it will light up and then turn off, I can hear something in the tv click off. The Model number is 55LW5300-UC
Add a comment
Most Helpful Answer
Hi @lgperforma41709
Here's an image of the Power-up boot check troubleshooting flowchart from the service manual that may help.
(click on image)
Score 1
Add a comment
Oh no, it sounds like a hassle with your LG TV! Firstly, check the power source, make sure the outlet is good, and the cord isn't damaged. Try a different outlet and do a power cycle - unplug for 10-15 mins, then plug and retry. Ensure your remote has good batteries, and also try the TV's power button.
If it persists, check for physical damage and consider a factory reset. If all else fails, contact LG support, especially if it's under warranty. If not, a professional technician may be needed. Be cautious with internals unless you're savvy. Good luck!
2 Comments:
I tried and Check all what you said. I need a service manual with a wire diagram so I can test the circuit boards and internal connections
by
@lgperforma41709
The service manual was linked in my answer above.
by
Add a comment
Add your answer
lgperformance@hotmail.com will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 132
