The charging port on the headphone melted
Basically, the charging port (usb-c port) on the headphone has melted and it’s not working now. How can i get it repaired
@salmanirfan my first point of interest would be why it melted. There may be more damage than just the port. Post a couple of well focused and large images of the damage, the board etc. with your Question.
If it is "just" the connector, you could replace it by soldering a new connector in its place. USB -C ports are a bit more involved due to the pins on the underside. You will need a good rework station and experience to replace it. To disassemble it use something like this video and/or this one It might be a slightly different model but it should still work for your Bose as well.
There will be a challenge to find the replacement connector. You may have to find one that fits, by scouring Digikey.com or Mouser.com I would recommend that you replace the complete charging board. You would need something like this Example only.
Hi, I had the same issue, I fixed it by buying a used charger port for bose 700 on Aliexpress. If it is out of stock, just wait a week or 2 for it to be restocked.
PS: To open your headset, you will need a Torx t6h screwdriver.
The link is https://fr.aliexpress.com/item/100500568...
(Select the 3rd option: Charger Port)
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 62
All Time: 230
