Would it be possible to drill out the hole for the proprietary jack?
Hello all,
I have wired Sony Headphones, MDR-100AAP. I think it's this one.
They have a proprietary mini jack connection. Meaning the cable itself is just normal 3,5 mm jack, but the connection won't fit normal mini jack connectors, because the entry hole is a bit narrower. My original cable only gives sound on the left side, so I want to plug in another cable. If I'd shave off a mini jack connector to make it really slim, it would fit. But that would not be a safe cable to use.
My question is: I wonder if I can drill the entry for the jack hole in the headphone itself a bit wider, so any regular mini jack cable will fit?
I'm long past the warranty period, so I will start drilling anyhow.
Cheers :)
Edit: Thanks @oldturkey03 for asking photos and the help link. Here they are:
the jack entry of the headphones
original cable fits fine
regular mini jack does not fit because its base is too wide (it does not go deep enough in because of that)
Even a seemingly narrow jack connection is too wide at the base
difference in length inside the headphones. regular mini jack connection goes in too short, because the base of the connection does not fit the narrow hole of the headphones
amount I'll be drilling. The material seems to be just green/yellow plastic until the black coloured base
do you think it's a good idea?
1 Comment
@jannn999 post some good pictures of what you are looking at with your question. Let's see what you got going on there. You sure about the jack being proprietary and not just being a 2.5mm jack? Pictures will help Adding images to an existing question
by oldturkey03
