Why isn't the battery working? I already replaced it with a new one.
Why doesn't the camera battery work, even though it has been replaced with a new one?
@agungpringgo the issue may not be your battery. The issue could be that the camera does not get any power. The first thing to check, would be the fuse that sits on the main circuit board, right past the battery connector. Check that one for continuity.
Use these guides Panasonic DMC-FZ70 to work on your camera. Once you get to the motherboard, post some good pictures of both sides of the board. That way we can see what you see and hopefully help you further. Adding images to an existing question
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 6
All Time: 148
@agungpringgo Do you have a multimeter so we can check the voltage of the batteries?
by Andrew S
