Why is my phone battery drain automatically
My phone was automatically draining. When I didn't use phone but also it's draining.
Hi @jitu43737
When you are not using the phone but the phone is still turned on, turn off the following unless you need them on for some reason and check if the battery charge takes longer to dissipate.
Turn off WiFi and Bluetooth and also disable the internet connection by turning off the Data saver settings. Go to Settings → Connections → Data Usage → Data Saver.
Only turn them on when you need to use them and turn them off when you're finished.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 14
