Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
How do I reset a disabled iPod Touch without a computer?
My iPod Touch 4th Gen will not enable. I forgot the password. How do I reset it without a computer?
Score 316
68 Comments
Hold down power and home button until logo shows up and will reset to factory downside is all data will be deleted
by
I don't have a computer
by
by
You can't do it without a computer
by
i have ipod 5 touch does it work on this
by
Show 63 more comments
Add a comment
Chosen Solution
There is no way to do that, unfortunately. You have to put the iPod into DFU mode and then use a computer to restore it. I would suggest trying to find a buddy who will let you use their computer. To DFU the iPod, have it plugged into the computer, hold the lock and home buttons until the device shuts off, wait five seconds, and then release the lock button while still holding the home button. A message should then pop up on the computer telling you that the iPod is in recovery mode and that you have to restore it. Let me know if you have any questions
Score 76
56 Comments:
this didn't hepl tell me an alternative method if possible
by
@abhisek neymar, just like Jason rightly answered, there is no alternative method. "There is no way to do that unfortunately. You have to put it into DFU mode and then use a computer to restore it." Follow his advise .
by
What happens if that does not shut it off
by
This happened to mine. I did exactly what he said and it is restoring as I am typing. Thank you so much! This helped and I can't wait even tho it will take an hour or so thanks so much!!(:
by
what if a message pops up saying there's an error occurred (3194) ???????????
by
Show 51 more comments
Add a comment
Requirements :
1. A computer (Mac or Windows)
2. An Apple USB Cable
3. Your iPod
Method:
1. Connect your iPod to a computer running iTunes using the USB cable
2. Make sure your iPod is turned on, the hold both the Home and lock buttons simultaneously and hold for 10 seconds
3.On your computer go to iTunes and click "Restore iPod"
4. Wait for iPod to restore and enjoy!
Hope this helps
Score 14
13 Comments:
I get a message that I have to restore the ipod before using it with itunes but when I click ok, the restore ipod screen goes away. How can I keep that screen up to restore it?
by
If i restore my ipod touch 4 will it delete my apps, music, pictures, etc
by
What if u don't have an apple account how do we do it then it will not let me I try using my aunts account and it will not let me
by
but windows doesnt recognize my ipad it keep saying usb not recognize
by
What if you have a chrome Book and not able to connect to iTunes i would ask my mom but she would say no so what do i do??
by
Show 8 more comments
Add a comment
all you have to do is hold the power button and home button at the same time for ten seconds then let go of the power button but keep holding on to the power button for 10 seconds. then it should restart.
Score 8
4 Comments:
i tried that before but when i did it still popped up saying iPod is disabled connect to itunes
by
it is not working
by
Let go of the power button but hold the power button on? That does not make sense
by
I know right
by
Add a comment
If you don't have one then you'll need to buy or get a lend of one I'm sure you no someone with a USB cable
Score 6
1 Comment:
Would iMac,MacBook include a usb cable
by
Add a comment
I don't have a computer and I forgot my password and the people I do know don't have a computer
Score 5
3 Comments:
As I stated before you need a computer to complete this process. Try your local library, apple store or best buy.
by
wow "the people i DO know" makes it sound like you live in a cave and the only people you DO know are the ones who you haven't eaten yet.
by
verizon stores will unlock or reset your ipod for free! u dont need a verizon account!
by
Add a comment
yes unfortunately you cant do anything without the computer i tried everything and still does not work. my charge bars are bent so it does not work i will try suggestions if any one has some very appreciative
Score 4
1 Comment:
verizon stores will unlock or reset your ipod 4 u for free, u dont have to even have a verizon account
by
Add a comment
Well basiclly you press the sleep wake button and home button for 10 secs till Apple icon appears. Then let go of the buttons. Hope this helps!
Score 3
3 Comments:
that didnt help at all i tried a couple of times but it didnt work ):
by
i found an ipod touch 2nd generation its has a password and i need help unlocking it.how do i do that without a computer
by
Close, you need to continue to hold the home button after 10 seconds and releasing the lock button. That is the difference between a forced reset and putting it into DFU mode. Alisha first off you should contact Apple and try to return the iPod. I am sure someone is missing it
by
Add a comment
i found a ipod touch, but ican't to delete the id and password.
Score 3
1 Comment:
Take it to Verizon they will unloOk or reset it 4 free, NO verizon account needed, takes 10 min
by
Add a comment
Can I plug into another phone using iTunes app then do the reset function? ?? Would that work
Score 2
Add a comment
Can someone help me unlock my iPod touch 5 i got it on letgo serial number is dj6kt0cff4k4 can someone help me out
Score 2
Add a comment
IPod 5 no enciende que se le hace
Score 2
Add a comment
well you get your usb cable and hook it up to an outlet than you take a pic then you will go tot he lockscreen and slide up so on the left hand side you will see a flash light Image than right next to it on the right there is like a watch images than you will click on that then you press the sleep/awake button then it will say slide to sut off under that it will say cancel you pres on cancel then you wil press the home button 2 times really face hope this work cause it worked on mined
Score 1
3 Comments:
What?Wheres the correct spelling?
by
i've erased my ipod, version: 421(8c148) model:MB52LL
by
Apple iPod 7.0.4. Serial number-ccqm345gffcj. Says connect to itunes
by
Add a comment
If you don't have a computer then go to the Apple store, and use one if those. They will let you use it.
Score 1
Add a comment
how do i reset a ipod if it wont go into dfu mod it just shows the apple logo
Score 1
Add a comment
Get my ipod said disabled CONNECT itunes how get off please help me
Score 1
Add a comment
I know how you feel, my dad will recover it, but try to find a nearest Apple store, or use your teachers MacBook or iMac! Hope it helps! I’m in 5th grade so this should help! :)
Score 1
1 Comment:
Apple store will let you borrow computer
by
Add a comment
How do I unlock my ipod without a computer
Score 1
Add a comment
Add your answer
kato will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 110
All Time: 484,298
