Identified By the model number F412DA on the bottom of the laptop. Can have an AMD Ryzen 3 3250u or Ryzen 5 3500u processor.
Laptop won't turn on by pressing the power button.
Laptop not turning on by pressing the power button , it only power on when the battery is disconnected and reconnected and plugged in . Then after this the laptop will turn on . I think that the button is not working , can you give me a solution in this because its very lengthy process to turn on a laptop.
Add a comment
It's charging but when pressing the power button the laptop is not turning on
Add a comment
If your laptop only powers on after disconnecting and reconnecting the battery, the issue is likely not the power button itself but a motherboard power circuit, static charge buildup, or faulty battery. First, try a hard reset: unplug the charger, hold the power button for 30–40 seconds, then reconnect and test. Update BIOS if possible. Check whether the power button feels physically normal; if loose, the switch may need replacement. If the problem persists, the battery or charging IC may be faulty. Visit a technician to test the battery and inspect the motherboard power section professionally.
Add a comment
Add your answer
View will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 11
All Time: 95
