Question Closed
My 2005 G.am wont turn over when I turn the key
when i try to start my car, i turn the key to start position and nothing happends all the dash lights come on but the car WILL no turn over... There have been times where i remove the igniatiion fuse and immeditly put it back in and try to start car and well its started but that is no longer working!!!!
Add a comment
1 Answer
To be it sounds like the coil in your starter relay is going bad. As long as your battery has correct voltage I would try jumpering your relay with a wire to see if thats the issue. It should be 4 prongs on your relay two for the coil and two for the load just jumper the two for the load and see if your motor kicks over and if it does you just need a new relay which is pretty cheap! Good luck!
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 935
