Repair guides for displays (or monitors) for computers or other devices with video output.
What is causing this on my screen?
I have an MSI Stealth Laptop with the 240Hz screen and just recently these dark areas showed up on the bottom my my screen. Looks like some of the LED back/edge lighting has stopped working. Anyone else have this issue or know for sure what it is?
The dark areas are hard to see in the picture. But in person you cant miss them.
Add a comment
Most Helpful Answer
It looks like the backlight in your screen is failing. An LCD replacement should fix it.
Score 2
Add a comment
Easiest fix: Replace the whole LCD panel for it.
If you want to try and fit a new backlight to the panel, You could try before you buy a new one.
But if you want neither, It won't hurt anything, Looks like only one row failed.
It won't break the whole laptop.
Score 1
Add a comment
Add your answer
Patrick Auer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 70
