When I was on call andi put in specker mode my mic is not working.
Specker mode mic fix
Iām sorry to hear that your Samsung Galaxy S9 microphone is not working when you put it in speaker mode. This could be a hardware or software issue, depending on the cause of the problem. Here are some possible solutions you can try:
I hope this helps you fix your microphone problem. If you have any other questions, please let me know. š
@kingofspades your AI (Bing, really) is getting unreliable. IT is starting to make stuff up. Check your last bullet point. Your "buy a replacement cable online from this link: Samsung Galaxy S9 Charging Flex Cable" links to this When I was on call andi put in specker mode my mic is not working. question, The one right here. The one we are on. AI is losing its direction here.
Your second link in the last bullet point. which is supposed to go to the iFixit toolkit goes to https://thedroidguy.com/how-to-fix-galax... and has definitely nothing to do with the tools. Your third link, which says "follow this video for a visual guide on how to replace the charging flex cable" links to a site which does not even remotely address that issue.
You are responsible for the accuracy of the information of your AI. Use it ethical, transparent and keep it honest.
@oldturkey03 I apologize. I will start to read over it more. I basely use bing because it is the most up to date with things. I will think of using a different AI
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 27
